Re: First steps since refilling + waterfall question
I think I screwed up the timeframe for adding the CYA on my other post -- I actually added it the night of the 23rd, so it's been about three full days, but in any event I take your point. The CYA test is especially expensive in terms of reagents -- it uses 7 ml each time along with 7 ml of water. I've maybe tested 3 times and I'm already about halfway through my supply.
I suppose you could mix up less as long as it was 50/50 if your CYA level was high. That doesn't do me any good right now. They really need to make a more sensitive reagent :-)
15000 gallon Pebble Tec with cartridge filter. Popular watering hole for local quail, doves, squirrels, &c, &c. Congregation of bees near the overflow outlet is a capital offense!
