Results 1 to 10 of 14
Thread: huge clorine demand
    sabres07 is offline Registered+ Thread Analyst sabres07 0
    May 2012
    Buffalo, NY
    Default Re: huge clorine demand
    Added info: I re-tested and FC was down to 18.5 which means I lost 15 ppm in less than 24 hours with no swimmers usimg pool. Water is crystal clear and I have held pool over shock level for 9 days. I need help!
    16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
    Virginia
    Quote Originally Posted by sabres07 View Post
    Did you lose CYA over the winter? As I understand it, CYA can be eaten by certain bacteria over the winter and the resulting byproducts (sorry, I forget exactly what they are) create a huge CL demand in the spring. I've experienced this several times, although for seem reason it did not happen this past winter. If this is the case you will just have to keep at it with CL until all the byproducts are gone.
    Hopefully someone more knowledgeable will chime in as well.
    BigDave's Avatar
    I don't claim to be more knowlegeable but, I would expect to see high CC, low FC and no (or severely depleted) CYA if sabres07's pool had experienced the CYA eating, ammonia excreting bacteria.
    Perhaps it's bio-load, although I'd expect to see some CC.
    Is there alot of pollen? Maybe there's lots of biological material in the filter being consumed by the chlorine not but reading elevated CC because the hich FC in the pool is doing away with the CC before it can be read. Just a Wild Antelope Guess. How's the filter?
    Virginia
    Ah, I missed that CC is measuring 0. Thanks for catching that.
    May 2012
    Buffalo, NY
    A few days ago, I thought maybe something was living in my filter cartridge, so I removed that and continued with my program of keeping the pool at shock level. Still no change. Also, I thought it might be the amonia issue due to degraded CYA because I had that problem last year. I have a 40-50 CYA reading this spring which is only down slightly from closing last fall. There was a lot of pollen a week ago, but has since not been an issue.
    My plan is to continue with holding above shock, but this is getting ridiculous!! Like I said, the water is crystal clear and inviting. No visible signs of any issue other than my crazy chlorine readings....
    May 2012
    Buffalo, NY
    Ok....this is getting frustrating! My FC went from 35.5 last nite at 11 pm to 19.5 at 8 pm tonite. This is getting expensive. There must be a problem that i cant figure out. I am about to recover this pool and call it a day!
    Since you said you checked your filter, I assume you checked other places such as your skimmer and pump basket. You might also check under any removable ladders and perhaps behind light niches. Something is seriously consuming chlorine in your pool, and losing it overnight means it's not the UV in sunlight.
    I also assume you test your chlorine level within an hour after you've added it just to make sure your chlorine isn't weaker than you think. So I too am at a loss. This is very unusual. Even if it were some conversion of CYA to ammonia and/or partially oxidized CYA, you should see your chlorine demand dropping and you would see at least some CC.
