I'd take the other two and -- carefully -- use a Dremel tool, die grinder, wood rasp, or small coarse file to open the slot, till you achieve sufficient flow.
To stabilize the work, you'll probably need to screw the jet into a 1.5" FIP adapter on a piece of 1.5" PVC pipe.
