Results 1 to 10 of 13
Thread: I need a pump lesson please
    Jul 2006
    Default Re: I need a pump lesson please
    Quote Originally Posted by mas985 View Post
    The easiest way to compare pump efficiencies is to look at each pump's head curve. You will notice that for a given head, the Northstar will have the highest flow of any of the pumps listed which also means the shortest run time for a given turnover. The extra money spent on the Northstar will probably pay for itself in the first year.
    Also, for an 8 hour turnover, you only need 80 GPM so 1 1/2 HP may be too much pump. 80 GPM for the Northstar is over 70 feet of head which is very unlikely if you are using at least 2" pipes.
    To learn more about pumps, head, turnover and other issues, I recommend this site as a primer.
    http://poolplaza.com/pool-pump-sizing-2.shtml
    http://www.poolplaza.com/pump-ratings.shtml
    Mark:
    Thanks for the great info. The link above is perfect!!
    Where do you live? Your pool setup up is almost what I am getting?
    I live in the Phoenix area.
    THX again..
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by gordonhyde View Post
    Mark:
    THX again..
    I am in Northern California, SF bay area.
    Mark
