Waste,
I don't think i really need the electronic valves. no spa or water feature. I just want to be able to run the pool functions inside the house.
heat settings, polaris run times, salt settings, pump times and lights. I guess i'm a bit lazy. Last time we had to go to the side of the house, track grass and mulch back to the pool area just to raise the heat a couple of degrees or kick the polaris on for a non-cycled cleaning. I was hoping to be able to do this all from inside the back door. will the aqualogic do these things?
), but it cuts down on the 'usefulness' of our pools - we had to sacrifice control of all of the 3 suction ports to allow for the spa
. As I said earlier, it's because we didn't know about the upgrade when the pools were plumbed, which s*cks for us and the customer. Glad you found the forum and hope you use it to keep a crystal clear and trouble free pool and, of course, if anything ever goes wrong.
