Thread: Bleach Calculator
    Default Bleach Calculator
    I know this should be obvious, but does anyone have a working link to the bleach calculator? I had one and lost it due to some computer problems. I have searched here and every thread I find with a link takes me to a dead link. Thanks so much!!
    ~Sherry
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Default Re: Bleach Calculator
    Quote Originally Posted by SherrySt View Post
    ~Sherry
    Try this link! http://richardfalk.home.comcast.net/...achCalc262.exe
    It worked a few minutes ago.
    Was posted on the Testing and Adjusting form sticky for using Bleach Calc -- thanks to ChemGeek for posting a working link!
    drband
    Last edited by drband; 07-08-2007 at 11:01 PM. Reason: corrected credit for link posting
    Thank you for the link. It is not working for me. I am using Firefox. Could that be my problem?
    drband's Avatar
    Gainesville, GA
    I use Firefox, too. But it works for me. It's possible that you have popups blocked, or that your anti-virus or firewall are preventing you from downloading the .exe file for bleachcalc. Sometimes that happens. Try enabling popups for this site and see what happens. When I click on the link, a dialog box appears indicating a download of the file will begin if I OK it. (takes a few seconds for it to complete preparations before the OK button is "live" and then it works. Let me know if it does not and maybe I can email the file to you.
    drband
    When I click on the link or copy and paste the link, it opens a new window and I get the following message:
    Server not found
    Firefox can't find the server at richardfalk.home.comcast.net.
    * Check the address for typing errors such as
    ww.example.com instead of
    www.example.com
    * If you are unable to load any pages, check your computer's network
    connection.
    * If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
    If you can email it to me, I would be truly greatful. My email is [email protected].
    Thanks so much!
    ~Sherry
    drband's Avatar
    Gainesville, GA
    sent it. Note instructions in the email for accessing the file. Hope this works for you. An alternate calculator is on the troublefreepool.com site. This calculator runs in your browser, so should run in firefox or IE. Links follow: (paste each one into your browser address bar to access it)
    new bleachcalc link :
    http://troublefreepool.com/files/BleachCalc262.exe
    poolcalc:
    http://www.minbar.com/pool_calc.html
    The poolcalc webpage can be saved to your desktop so it can be used off-line if needed. It's a really user friendly way to show all of your test results and chemical needs on the same page.
    Bleachcalc is a great tool, too and is really good at giving you the data for one chemical at a time. After you've been testing for a while, either tool will do the job.
    drband
  1. Bleach Calculator
    By ThePoolFool in forum DPD-FAS based testing
    Last Post: 06-07-2006, 12:44 PM
  2. bleach calculator
    By kwickimom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2006, 04:39 PM
  3. Bleach Calculator
    By PatL34 in forum General Interest
    Last Post: 05-19-2006, 10:17 PM
