You know the drill - bleach, bleach, bleachoh yeah, and POP
Northeast PA
Yup, I know the drill. After all, I've written it about 100 times! And it's working. Bleach/LC 2-3x/day, filter 24/7. Backwash as needed, vacuum and brush everyday (thank goodness for my Blue Diamond) and lots of POPP.
Even though the water was cloudy tonite my FC was 10 and my CC was .5-1.0. Added another gal of 12.5%...which should take it to 16ppm--just above shock level for my CYA.
It's getting clearer and the process is working. I have POPP, too.
POP? POPP? Sorry, I haven't heard that term yet. Quick definition please? (My guess is POP=Plenty of patiencebut I have no idea what POPP is. POOP = what you said when you got back to find a marsh instead of a pool.)
Thanks! -ZephanS
AG BF 13.5'x23.5'x54" (wups) Diamond Star (Wil-bar) purchased 5/30/2007 from sunenterprises.com. 2hp pump + 150lb sand filter (both WaterWay combo) using 75lbs zeobrite + SWG.
Dug and built ourselves in ~30hrs by ~7/4 thanks to PF (esp. hrdennis,nwmnmom,matt4x4,Waste,CarlD, &others). ~$5,500 total cost.
Chairman Mao was a great adovcate of returning to work the rice paddies once in a while!
Failing that, just paypal $299 to Spensar'[email protected] and a representative will deliver a magic solution. Please be sure to follow the instructions carefully: it must be used with your filter on and the level of chlorine as per the instructions. If followed, guaranteed to kill the algae!!
IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
Heating? Great info on why a solar cover saves $$$?
http://energy.gov/energysaver/articl...ng-pool-covers
Hee hee, there are a lot of ways get parted with your money, but thanks to all on this forum we have learned how to avoid this with our pools- now for the rest of my house????
Northeast PA
POPP: Pool Owner Patience and Persistence!
Magic goop--just like instant water: Fill a cup from a drinking fountain water, add Instant Water, stir and VOILA! water!
I has the same problem in June when it rained all the time. Took about a week to get cleared up.
We got a bunch of rain again a couple weeks ago. I managed to catch it in time. I started pump 24/7 and tons of bleach when it was getting cloudy. Still took a week but I got it.
I've got a HUGE box of DE I bought at Lowe's when I only needed (1) Cup. I didn't think about adding that. I'll do that next time.
21' AG 48" AquaLeader
Central Illinois
Don't add too much--1/3 to 1 cup is all you need--if your skimmer stops working, just backwash the filter and add less DE. You need to add more DE everytime you backwash. Actually, you don't need to add it, but if you want the extra filtering DE gives sand you do. I have been using DE for 2 1/2 seasons now and STILL am on the first 10 lb box. DE doesn't go bad.
My pool's now pretty much clean. The water is clear but not the crystal, crystal clear I like and usually have.
We had a lot of rain while I was away and I think that did it.
