Cloudy Water - I think
Hi All,
My opinion is that. my water is cloudy. I don't remember it being this way at the beginning of the season (it's my first full season as a pool owner). I was wondering if some of you could comment regarding underwater clarity with their own pools. My pool is 33 feet long. From underwater, I can see my return jets up to about 25'. But, it is "cloudy." Any further than 25', I can't see them. I think I recall seeing them crystal clear from any point in the pool. And, I think the problem is getting worse over the past few weeks. From outside the pool, the water looks fairly clear. You can see anywhere in the pool with no issues - including the bottom. So, most people think I'm crazy!! When I'm in the water, I can see a digital watch that is lying on the bottom at my deepest point (5' 10") - so depth is not my issue.
About the pool: 16x33 fiberglass. Started BBB in June - and have been pretty dilligent keeping the water in balance. Current reading:
Cl: 6
CC: 0
CA: 60
Ph: 7.2
CYA: 65
Alk: 90
Borates: 50
Have not shocked since July - it was my only time this season I shocked. I've been keeping the Cl between 5 and 10 according to Best Guess. The pool is not consuming Cl out of the ordinary. On sunny days, it'll go through 2-2.5. On cloudy or rainy days, it barely uses Cl. So, I'm not sure if shocking will help. I know the last time I shocked, the Cl took a lot of days to return to normal. So, with less than 4 weeks left in the swim season, not sure if I want to shock.
What else went in the pool? Lots of Borax when I was using pucks - probably about 8-10 boxes. Since on BBB and having more borates, the Ph stays pretty steady and I have not added borax in about 2 months. I have used about 4 quarts of Metal Magic throughout the season to get rid of staining. Last use was about 3 weeks ago. Could this be causing cloudiness?
In reading the forum, I understand that cloudiness can be caused by higher Ph or high Calcium, neither of which I have. Also, since my Cl levels are easy to maintain, I'm not thinking Cl will fix the issue.
Pump runs 8 hours a day in 2 shifts.
Thoughts out there? Also - again would like to get a poll out there how clear can folks see underwater in their pool (width not depth).
Thanks !!
