Thread: Removing Metal stains
    .Joppa, Maryland
    Default Re: Removing Metal stains
    Should I be backwashing my DE filter during this process? Is there a way to eliminate the metals other than a complete water change?
    Thanks, Marty
    Quote Originally Posted by MartyW View Post
    Only if your filter pressure rises too high.
    Basically, no, assuming there are no metals in the fill water. If you REALLY know what you are doing you can sometimes get them to 'stain out' on the filter media and then change out the media (DE in your case) but it's tricky at best for someone who really understands the chemistry involved and NOT something to try if you don't.
    Thanks, Marty
    Welcome!
