Frustrated
OK, I read a lot about the BBB, I want to try it. this is the 1st year my pool does not clear up after 7 days 24/7 running the filter sand.
I have 23000 Gls, in-ground Gunite pool. Water analysis: TAC 5, PH 7.4, TA 90, CH 200, CYA 55.
Brushed and vacuumed twice daily, but the water still milky. What I also noticed this year, every time i pour Granulate chlorine, 2 minutes later, white stuff surfaces to the top of the water and stay there for good half hour, what causing this? also how many gallons of bleach and how many box of borax I should use for 23000 gallons of water. Help Please . Thank you
