Thread: hth 3 in 1 tabs
    Default hth 3 in 1 tabs
    hello all, ive aquired some of the hth 3 in 1 7 day skimmer tabs from a friend that no longer has a pool. they are the calcium hypo tabs not the trichlor tabs and they are 3 inch tabs. my question is can i use them in a floater instead of dropping them in the skimmer. the reason i ask is because they are supposed to be 7 day tabs but in the skimmer they only seem to last 1 1/2 days. any help would be appreciated. thanks
    Default Re: hth 3 in 1 tabs
    I would ONLY use them in a new floater that never held Tri-Chlor tabs. If they are the ones that are NOT encased in a plastic shell, they are lousy performers, as you said, only lasting a day and 1/2, if that, in the skimmer.
    But, as long as your calcium levels aren't high you can use them.
    ok thanks, they are the regular pucks that are not in the plastic shell
    If you check I believe you will find that they contain copper. Read the ingredients.
    Eeww!
    The ones I once had did not. But HTH is big on selling combined stuff that makes you THINK you are taking care of multiple issues at once, but actually adds to the problems.
    Eeww!
    They had both kinds at one point. Not sure about now but the ones we sold did contain copper.
    What did they do, grind up a penny (pre-1982) and toss it in? They could STILL grind up a nickel and toss that in (75% copper, 25% nickel)
  1. How to Use Trichlor Tabs
    By TheKs in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2013, 08:14 AM
  2. Floater Tabs
    By TheKs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-14-2012, 09:20 AM
  3. septic tabs?
    By lguti69 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-20-2012, 07:59 PM
  4. Bleach VS Tabs
    By samtex in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-14-2011, 02:15 PM
  5. Tri-Chlo Tabs
    By cajunfla in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-28-2006, 01:46 PM
