Results 1 to 10 of 36
Thread: pool opening delayed until i can uncloud my pool
    Default Re: pool opening delayed until i can uncloud my pool
    Quote Originally Posted by madwil View Post
    What happened to the warning about another post? my post went straight thru
    ?????????? Don't know what this means.
    May 2011
    I'm assuming like many forums this forum let's you know if someone has posted as you were typing your reply. And it allows you to view it before you reply so you can alter your response if needed.
    As he was replying someone else did saying something similar to him and he never was prompted that another reply had been posted whe he was typing his.
    Pools 1/3 empty. Cmon sump pump you can do it!
    Apr 2011
    virginia
    yep, resp has it right; Ben posted while I was typing, so I went back and edited; but I know in the past it's stopped and given me the warning prior to posting my message...
    May 2011
    Pools 2/3 drained and I'm glad I made this decision. The pool cover came off during the winter and there is a ton of debris on the bottom. Leaves and dirt and etc. I'm gonna scoop it all out, give the pool a nice wall and floor sweeping and refill immediately
    On this forum? I have been on PF for a decade and have never seen that warning with any of our software versions.
    May 2011
    Quick update. Pool is cleaned and refilling. Taylor pool kit is here and once it's filled I'll adjust the levels and post readings. Thx all
