Results 11 to 16 of 16
Thread: Pool Liner holes at Return Connection
    Default Re: Pool Liner holes at Return Connection
    I'm pretty sure I've put the tip about using a wallpaper seam roller here to keep the edges from 'rolling' up... ? (if not, I gotta find the time to type up my patching info )
    Quote Originally Posted by waste View Post
    I use a rubber roller used by the tile, formica and vinyl flooring guys. Same idea.
    Actually, I try to NEVER use it at all!
    You want to write a sticky . . . that I can migrate to PoolSolutions? A "How to patch or repair your liner?" page? We can start it as a thread here, to let people comment and correct (at least my stuff needs corrections!) before moving it to a static page on PoolSolutions.
    Now that we've passed the 4th, traffic will began dropping and I'm going to go back to working on PS pages, cross links, stickies and . . . boring stuff like firewalls and security add-ons that will allow me to relax some of the new member entry hurdles.
    Ben, I'll gladly try to type liner patching info up, so it will be in one place - and I have no doubts that it will need a little 'tweaking' once I get some feed back on what I write
  6. #16
  1. AG liner to return seal questions....Please
    By A71SS4ME in forum Above-Ground Pool Construction & Repair
    Last Post: 04-14-2012, 09:11 PM
  2. Suggestions on RIPPED liner by the return
    By nanalima in forum In-Ground Pool Construction and Repair
    Last Post: 05-18-2008, 11:33 AM
  3. how should I "cut in" skimmer and return holes in the liner?
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 07-06-2007, 12:53 AM
  4. Liner Holes--Forwarded from another forum by request
    By JohnT in forum In-Ground Pool Construction and Repair
    Last Post: 05-24-2007, 04:05 PM
  5. Hayward eyeball return connection- Long
    By EricF in forum Pool Equipment & Operations
    Last Post: 05-26-2006, 12:30 PM
