Thread: K1005 I-care Test Kit
    Default Re: K1005 I-care Test Kit
    Hayward will sell the K-1515 FAS-DPD kit for list at about $20-$25 which has the test vial, 0870 powder, 0871 reagent, and 0003 reagent, plus a nifty box to store it in. Add that to the K-2005 and you have the K2006. The K-1000 OTO test kit from Taylor upgrades the OTO and pH test to the same as the K-2006, and includes R-0014, rather than R-0004 for the pH test. R-0014 includes a chlorine neutralizer so it can read accurately in higher chlorine situations (Chlorine makes pH read high). list on the K-1000 is about $10.
    If you have the K-1515 and K-1000, the only other tests you need are the T/A, CYA, and CH tests (acid and base demand are worthless).
    Note: Waterbear and I had a discussion on this last recommendation. I have moved every post after this one to the China Shop where it really belongs at both Ben's and 'Bear's suggestion.
    Look for Acid and Base Demand.... C.
