Results 1 to 10 of 18
Thread: Keeping Animals Safe
    Mar 2012
    Nevada
    Default Re: Keeping Animals Safe
    Quote Originally Posted by AnnaK View Post
    The tragedy of pets getting trapped under a solar of winter cover and drowning can be avoided with a pool fence. Even animals with excellent swimming skills can and will get disoriented once they're under the cover and will drown. Pet-appropriate steps or ramps are a must-have, and you must show the animals how to use them to exit the pool, but they are frequently of no use in cases where the pet is trapped under the cover. They panic, they forget where the exit is, they drown. Do a search on Scamper Ramp which is a pool exit ramp for dogs. It works best on inground pools.
    Yes! The Scamper Ramp. I had found those and forgotten the name.
    We would like to remove the fence. There are safer pool covers, aren't there? If we have to, I guess we can leave off the cover completely.
    As to breeds that can't swim, I haven't heard that. Some dogs dislike water or are afraid of it but as far as I know, all dogs can be taught to swim.
    I don't know how accurate it is, I have just read that. *shrug*
    I had a chow mix that couldn't swim her way out of a mud puddle. Hated water, and I think she just was too panicked in the water to learn. My German Shepherd, however, absolutely LOVES the water!!
    Lehigh Valley, PA
    Quote Originally Posted by veghead View Post
    Yes, there are pool covers that will hold the weight of an elephant but you probably won't want to put that on at the end of each swim session.
    The Scamper Ramp is a nice addition to the regular pool steps, sort of an emergency exit if the dog forgets where the steps are, but neither the ramp nor the steps will do any good if the dog is under the cover and panics. My dogs are excellent swimmers. One of them followed me on the pool deck one year–I hadn't latched the gate properly–and dove into the water. The pool was covered with the solar cover at the time. He got tangled up in it and looked awfully darned scared, I'll never forget the impression on his face and the frantic splashing, trying to free himself of that huge sheet of bubble wrap. Very, very scary!
    Both gates now have a self-latching spring installed.
    I have stopped using a solar cover after my Schanuzer almost drowned! She thought it was a solid surface and jumped on it! Luckily we were by the pool when it happened and jumped in to get her out of the water. She was trapped under the cover! This was several years ago and we have not covered the pool since!
    Keep the pool fenced and the gate closed and it should never be an issue. My huskies love to swim, but we only let them in the pool area when we are there. You want the solar cover on the pool all the time when you are not using it. If it costs you $1,000 to heat it without the solar cover, it will cost you about $100 to heat if you use the cover.
    Apr 2011
    Hi,
    We have a male 2 yr old Rottie we've had since 8 weeks and he loves to swim. He doesn't like to jump in from the deck which is 3" above the pool ledge so I built him a ramp that's hinged to the deck and he loves it. He is in and out of the pool by himself all summer. He swims over to the wedding cake stairs and climbs out.
    This is an 24' above ground with a permanent deck 1/2 way around. Although I heat the pool I won't use a bubble cover for the same fear. During winter I run a 3' high piece of cyclone fence across so he can't get near it. Looks like hell but I'd be devistated if something happened to him. I realize I'm wasting money by not using the bubble cover but I also really enjoy looking at the water vs the cover.
    That's my story.
    Cooper
    Mar 2012
    Nevada
    The pool does not have a heater, but I do live in the desert southwest. I am thinking about getting a roof solar heater. Quite honestly, I think the bubble solar covers look like heck too. I know, though, they will cut down on cleaning and help with retaining heat.
    Lehigh Valley, PA
    Hi Cooper,
    I'm very interested in learning more about the hinged ramp you built. Do you have photos of it posted somewhere?
  1. keeping up
    By Beast in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-03-2011, 06:42 PM
  2. START UP: Keeping CL up
    By chuck9997 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2010, 02:47 PM
  3. PLEASE HELP!!!What to do with SWG and keeping pool open
    By georgiapoollover in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-01-2006, 12:19 PM
  4. Keeping in the Heat?
    By tcjones in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-11-2006, 07:30 PM
  5. Trouble Keeping Chlorine
    By mkamp1515 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-21-2006, 08:07 PM
