Results 1 to 9 of 9
Thread: Salt water generator
    Jun 2012
    Massachusetts
    Default Re: Salt water generator
    Thank you for the information. Put the other bag of salt in and produced chlorine. Very happy that it's working. I have every intention of putting in the stabilizer now. My ph did raise a bit (not sure why, I guess). I use test strips but I will take a sample to the pool store to make sure it's accurate and adjust accordingly.
    membership upgraded. -ben
    Quote Originally Posted by kmac1196 View Post
    The reson the ph went up is because when the cell is working it aerates the water and that causes CO2 to outgas and THAT is the main cause of pH rise in ANY pool. What is your Total Alkalinity? (NOT adjusted total alkalinity and not done with strips. They do not have the resolution (precision) needed to adjust TA!) High TA will cause pH to rise faster than low TA.
    FWIW, Pool store testing is often not that accurate and is geared to sell you as many chemicals as they can. Best investment you can make would be in a good test kit. Also, you might want to consider disconnecting the copper electrode so you don't put copper in your water.
  1. salt water generator
    By Alleno in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-21-2012, 08:52 PM
  2. should i get a salt water generator?
    By bluprint in forum In-Ground Pool Construction and Repair
    Last Post: 06-26-2010, 02:59 PM
  3. Salt Water Generator
    By sryan in forum Pool Equipment & Operations
    Last Post: 04-19-2007, 01:08 PM
  4. salt water generator
    By clhealy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-15-2006, 04:03 AM
  5. copper and Salt Water Generator
    By kwhoughton in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-05-2006, 11:20 PM
