Re: Pool Survived Vacation! ?? Chlorine levels
BigDave
Sorry, I didn't mean to scare you, you've been asking what's going on - so - I gave you my thought about your chlorine demand.
I think that 4ppm FC is too low and you need to add some more bleach or Liquid Chlorine (LC) sooner than later.
If you don't see or feel any algae then let's stay with regular FC (5ppm - 10ppm) levels for a while.
Well walls DID feel little slimy but water still clear..Test FC was back down to 2 PH down to 7.4 SO I put in 4 cups of the liquid shock. Is that enough? Chlorine was so stable for so long.. Do you think this is cause of heavy rains?? Was no heavy use age..
thanks again...
15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar; winter: Not bought yet; ; PF:21??
