Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 57
Thread: Strange test results -- very high combined chlorine (CC)
    May 2013
    Northwest Indiana
    Default Re: Strange test results
    I reposted the motor question in the pool equipment section with more details... I did find a model # on the motor (sp2600zlc) but after searching the web, i still cannot determine the hp. If that's still not enough info, i will post photos.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    Hayward motors will have a SP number, but for example, a SP2610x15 is a 1HP pump that gets uprated as a 1.5HP pump.
    May 2013
    Northwest Indiana
    Ok, to keep things tidy, i will continue the motor discussion here:
    http://www.poolforum.com/pf2/showthr...ize&highlight=
    And it siezed this afternoon...
    Back to test results... Any answers to the questions/situation below? More importantly, what can i do while I'm replacing the motor to keep things improving or at least prevent them from getting worse?
    Quote Originally Posted by Themadczar View Post
    I have 44oz of cya... Do i just follow the procedure here...
    http://www.poolforum.com/pf2/showthr...Way-to-Add-CYA
    All 44 oz at once?
    Also, these are my chlorine levels... Does this make sense?
    5/29
    5pm fc is 6 ppm, cc is 5 ppm
    8pm added 96 oz. 6% bleach
    10pm fc is 5.5
    5/30
    7am fc is 7.5, cc is 2
    7:30pm fc is 2.5, cc is 7.5. Then added 384 oz bleach
    8:30pm fc is 9.5, cc is 5
    5/31
    7am fc is 4.5, cc is 9
    6:30pm fc is4, cc is 10. Then added 384 oz bleach
    10pm fc is 5, cc is 12.5
    6/1
    7am fc is 5, cc is 11
    6pm fc is 14, cc is 5
    Numbers seem to be all over the place.... Not sure what to do now.
    Back to test results... More importantly, what can i do while I'm replacing the motor to keep things improving or at least prevent them from getting worse?
    1. Get your CYA up.
    2. Maintain chlorine levels.
    3. Maintain pH in the 7.0 - 7.4 range.
    Use dichlor, which will add CYA and keep the pH down. Sams Club is likely the only reasonably priced source of undiluted / unblended dichlor.
    Use bleach till you can get some dichlor.
    May 2013
    Northwest Indiana
    6/1
    10pm shut off pump
    6/2
    8am fc is 14, cc is 5. Started pump back up (still loud)
    5pm pump motor seized
    9:30pm fc is 10, cc is 4
    6/3
    8am fc is 5, cc is 10
    7:30pm fc is 12, cc is 3.
    Why are the fc and cc levels fluctuating so widely when the last time I added bleach was 5/31 at 6:30pm? It seems that in the morning fc is low and cc is high, but in the evening the levels flip to high fc and lower cc... And how does fc jump from 5ppm in the morning to 12ppm in the evening without introducing any chlorine? I'm just not understanding.
    Still working on getting 1) a new motor 2) dichlor... In the meantime I added 2 more gallons of bleach tonight and vacuumed with a catfish to clean up some debris and move some water.
  6. #16
    May 2013
    Northwest Indiana
    Update... Pump motor replaced and running again. Reagents delivered (ran out of 8071 already). And i have dichlor. Back in business.
    Added 2lbs dichlor last night.
    Tested at 9pm tonight.
    Fc=4.5
    Cc=10
    Ph=7.2
    Ta=300
    Ch=350
    Cya= about 10 (too low to measure, but some is present now and the 2lbs of dichlor should amount to 9.6ppm)
    Added 3 more lbs of dichlor tonight.
    Retested at 10pm
    Fc=6.0
    Cc=19
    I will retest in the morning... Anything else I should do?
  7. #17
    May 2013
    Northwest Indiana
    7:30am
    Fc 3
    Cc 15
    Very frustrating.
  8. #18
    BigDave's Avatar
    If you'd like to work up an estimate of how much chlorine will be required to clean up your pool, perhaps you could try: Bucket testing for chlorine demand.
    Be calm. Frustration and impatience very often drive us to look for a "Magic Fix". "Magic" is never what it appears to be and in a pool usually makes the mess worse and the cleanup longer and more expensive.
  9. #19
  10. #20
    May 2013
    Northwest Indiana
    Water is clear with a very light green tinge. Sides are not slippery, and brush is never green after brushing the pool. Normal taylor 2006 test process... 10ml pool water. Scoop of powder (turns red). Count drops of 0871 until it stays clear. Each drop is .5ppm fc. Add 5 drops of 0003 (turns red again). Count drops of 0871 until it turns clear again. Each drop is .5 ppm cc.
    I know the numbers are bizarre. That's why i keep posting/updating here.
    I intend to add 4 gal of bleach tonight unless someone suggests differently...
  1. Combined Chlorine High
    By StratDoc in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-09-2012, 09:30 AM
  2. Strange test results, help!!
    By lisak in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-20-2010, 04:59 PM
  3. Initial test results...green ring, combined chlorine...HELP!!!
    By Sheri in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-16-2010, 12:51 PM
  4. Super high combined chlorine
    By themaccs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2010, 03:45 PM
  5. High combined chlorine level won't budge
    By Carolina in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-13-2006, 09:54 PM
