+ Restricting flow on a centrifugal pump does not cause overheating, so long as sufficient water passes through the pump, to prevent the water itself from getting hot. One GPM is sufficient to accomplish this.
+ Restricting flow to 1/2 of maximum will REDUCE electrical consumption.
+ The only way to measure the flow is with a flow meter, OR by discharging the flow into a container of known volume, and timing how long it takes to fill. BUT, you can 'feel' the flow, and tell when you've reduced flow rates by 1/2 or more.
+ Flow rate of the SuperPump depends on your piping AND on which "3/4 HP" pump you have: uprate or full rate.
