Thread: starting fresh with new liner....
    Southern Ontario
    Default starting fresh with new liner....
    We are patiently waiting for our new IG liner to be installed....looking forward to not having to deal with liner pulls and shrunken old liner issues this year!!(....not sure where to begin with water chemistry when the pool is refilled. Any pointers on where to start....chlorine, stab...???
    Default Re: starting fresh with new liner....
    Heather,
    While you are waiting, so some reading here on the forum, especially the stickied threads and also over at www.poolsolutions.com.
    Do you have a Taylor K-2006? If not, go ahead and order one. (Test kit link below.)
    As the pool is filling, you can add some bleach to keep it from turning green until it is full enough to run the pump. Just pour a little bleach slowly around the pool when you have a couple of feet of water in there and use a clean broom, oar, or something to stir it up.
    Once it is full, you will need to decide if you want to chlorinate with bleach and add some CYA separately, or use dichlor for awhile as it will add chlorine and CYA. If you decide to use dichlor, get it at Sam's. Other places add a bunch of unwanted stuff in their dichlor. Dichlor is acidic and will push your pH down, so you should have some Borax on hand to use if your ph gets too low.
    Come back if you have further questions!
    May 2013
    Texas
    Heather,
    Everything that Watermom just said!!!!
    Just had my new liner installed, and while i was waiting i ordered the Taylor K-2006C and got familiar with how to test. Some good vids on how to use the kit on youtube, along with the great advice here. This method is incredibly easy once you study it a bit, and more importantly, incredibly easy on the check book....
    rectangular IG pool
  1. Starting fresh
    By dubbedout in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-28-2013, 05:28 PM
  2. How Do You Start The BBB Method from a Fresh Refill?
    By markintosh in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-07-2011, 10:13 PM
  3. The Chlorine IS Fresh
    By Spensar in forum General Interest
    Last Post: 08-10-2007, 11:43 PM
  4. Concrete behind liner starting to poke through
    By poolbee in forum In-Ground Pool Construction and Repair
    Last Post: 07-07-2006, 09:17 PM
  5. NEWBIE - How to make fresh water ready to swim?
    By bluenote in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-12-2006, 06:03 PM
