Thread: Hello!
    May 2014
    Texas
    Default Re: Hello!
    Thanks for the reply and the upgrade!
    It's definitely and in-ground pool. I'm not certain if it's Concrete or Gunite - How can I tell?
    I calculate my pool gallons roughly when I first got it so it's absolutely possible that it's incorrect. It's an odd shape with a connected spa. It's closest to a rectangular pool but tapers off like a kidney shaped pool. Here's a gallery with pictures of my pool. I'll take any measurements you think will help! http://imgur.com/a/f4RRl
    14k Gal Concrete Oval Pool - Hayward DE6020 Filter
    Default Re: Hello!
    Quote Originally Posted by JustAlex4tw View Post
    Gunite is one form of concrete.
    It's not too critical, if you follow the dose => test => dose again approach I advocate. If you try to use the pool store, or even the PoolCalculator.com approach of 'dose all at once', it becomes critical.
    Overdosing with chlorine is almost never a problem. Don't try to single-shot doses of anything else, and there won't be a problem.
    Default Re: Hello!
    Edit: volume is not too critical, as long as you don't follow the 'dose all at once' approach.
    We may need a better estimate, if at some point you decide to tackle those stains.
