Results 1 to 10 of 12
Thread: Rock waterfall gets my pool dirty
    Default Re: Rock waterfall gets my pool dirty
    Post a larger picture of the water fall while running, and then another larger picture taking looking at the fall from in the pool, but focusing on the water's edge where any net would have to attach.
    Sep 2011
    Thank you PoolDoc I will do that. Just a note however that every attempt to post a larger photo on my original post was rejected as too large.
    send them to [email protected]
    And, reference the thread number in your email. (Thread # 24124)
    I got your picture and video; see below.
    What I would do is go to a local sheet metal shop that specializes in SS restaurant counters and sinks, and have them cut and punch 2 strips of 14 or 16 gauge 316 grade stainless, about 1.25" wide, corresponding to the 2 lines I added to your photo. I'd also have them fabricate (3) J-hook clips that I could mount to the edges, and to the large rock in the center, and then slide the rear strip into. You'd probably need to make mounts points of 5/16" SS all-thread, epoxied into DEEP 3/8" holes, and attached with SS cap nuts.
    You could make the bag out of this material: http://www.onlinefabricstore.net/4mm...esh-white-.htm
    I'd assemble it with white stitched velcro to make it remove-able.
    . . . but it would be expensive to hire it done. The shop I use locally won't make anything unless I give them a drawing. The strips + the J-hooks would probably cost $100. Getting the SS all thread and cap nuts would take a couple of hours, unless I could find it online. And drilling those holes without damaging anything would take new bits and a lot of care.
    If you don't have the skills to put it together yourself, be careful. This would NOT be standard pool work: not many pool guys could do that for you; it combines too many odd skills.
    Good luck!
    Sep 2011
    That's similar to what I had in mind but it just seems so complicated. Although my pool is plaster/gunite I had it fiber-glassed which improved it dramatically. I'm definitely not going to drill into it but maybe a good adhesive would do the trick. I will re-post if I actually do something. Thanks Ben.
    To make a permanent and effective solution for a problems like that is often rather complex . . . unless you can just pay someone else to do it. Unfortunately, I think you'd have a hard time finding someone who could and would make something like that.
  1. Fixing cracks in pool waterfall
    By Tecka in forum In-Ground Pool Construction and Repair
    Last Post: 07-23-2013, 06:50 PM
  2. Rock crystals on bottom of pool??
    By pedsrn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-11-2007, 05:05 PM
  3. Why is my pool so dirty!!!
    By bizbad in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-26-2007, 05:27 PM
  4. Can I close a dirty pool?
    By housemom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-01-2006, 02:14 AM
