Intex 16x48 Ultra Frame Pool
Just got this pool setup. I am making my first post here on this forum for more info on maintenance. I also have a small amount of water under the pool. I didn't see the water level drop overnight but the water remains under the pool. It's a very small amount and the guy at the pool store said a little could be normal as the ground was a bit wet when I setup the pool. I laid down 2 heavy duty thick tarps. I didn't think the water could go through the tarps. The guy at the pool store gave me a bag of salt to spread around and said that could help fix any small leaks from the pool settling. What do you guys think? Also can someone point me to the maintenance link?
