Results 1 to 10 of 10
Thread: Where do you buy bleach????
    May 2013
    Concord,ca
    Default Where do you buy bleach????
    I keep seeing Aldis, Mennards and the like. Im in northern Ca. we have none of those, no Piggly Wiggly most hardware stores don't have it. Walmart and Safeway still wave it for about 3.45 a gallon ( or whatever that is). I noticed Chem Geek is in San Rafael so he's probably buying his from Nordstrom's Rack Just wondered what everybody else is doing
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    May 2014
    Plano, TX
    Default Re: Where do you buy bleach????
    We get our bleach at Aldi, but since you don't have that option, you might look at this
    http://www.homedepot.com/p/HDX-121-o...8211/203420868
    The MSDS says it is 8.25% regular bleach - Sodium Hypochlorite. Here in the Dallas area, it's about $3.00 for 121 oz.
    Fresh 12.5% commercial bleach is readily available from some pool stores, often in reusable multi-gallon containers. South Florida is the only area where this is consistently the case, but it is also true of other areas, on a hit or miss basis.
    It's worth checking into.
    But, do NOT buy stale boxed bleach -- it tends to cost more and but be stale.
    Quote Originally Posted by dansdad View Post
    Very funny. I actually buy 12.5% chlorinating liquid which is Hasa brand from Herb's Pool Service. I think it's around $3.80 per gallon if I'm not mistaken. I buy a case of 4 gallons at a time and return the case and bottles to exchange for a new one (there's a refundable deposit on the bottles and case).
    Default
    Wow.
    I wonder what the price of bulk bleach is now? The last time I bought a tanker load of 15% (fresh, so about 17%) bleach, I paid about $0.87/gallon for 4,000 gallons. It's been about 15 years, though.
    Oh, by the way Richard, Powell Fab has recently come out with a process for 30% bleach:
    http://www.powellfab.com/technical_i.../hsls_faq.aspx
    Cool. Though in practice one still buys 15% or less concentration, but it's nice to know it lasts about twice as long and also will build up salt in the pool more slowly.
    Midwest
    In Chicago land, American Sale has 12.5% for $2.49/gal.
    That would be cheap if it really is 12.5%, though often the higher percentage bleach is not as high as advertised.
    Jul 2014
    Madison, WI
    Quote Originally Posted by Shredhead View Post
    I don't know if it's a midwest thing or not, but a store in Madison, WI that I use sells 12.5% sodium hypochlorite for $12.49 for 5 gallons ($2.50/gallon.) It's a heck of a drive, so I have to tack on the cost of a tank of gas for the round trip though.
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    May 2013
    Concord,ca
    That is just killing me. All I get is wm at 3.15 gallon at 8.25 and I'm not sure what the pure chlorine from that is prob. 7.50 maybe. Saw Home Depot 2.99 gallon BUT not sure how fast the turnover
  1. Storing bleach outside; decomposition of bleach
    By tmess13 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-03-2013, 08:24 PM
