Results 1 to 10 of 17
Thread: Need help getting my pool right for birthday party this saturday
    Default Re: Need help getting my pool right for birthday party this saturday
    Amazing how when you come to the pool store with an algae problem and you have a vinyl pool, they INEVITABLY "recommend" (ie sell you) calcium--and then recommend using Cal-Hypo to chlorinate. Calcium is USELESS in a vinyl pool! And the Cal-hypo adds even MORE calcium that you don't need.
    Now Cal-Hypo, used appropriately, is a fine product, and a good way to shock a pool that isn't already high in calcium. But it's irritating to us that pool stores CONSTANTLY push calcium to customers with algae problems when it cannot help at all.
    Usually, but not always. I've got a couple of threads going, where I've mentioned that cal hypo can be used to REDUCE calcium levels. But it involves that whole 'tweaked pH', upstream of the skimmer dosing thing that I've danced around for years -- because it can be dangerous if chemicals get mixed up.
    If you just dump it in the pool, per the label, yes, it usually raises calcium levels. (I suspect, but haven't tested, that it will LOWER calcium levels somewhat if you cloud the heck out of the pool, then push the pH up a bit and filter or vacuum the cloud out.)
  1. No free chlorine in AG pool after party
    By sue&Joy in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-11-2013, 05:13 PM
  2. Cloudy Pool after a party
    By onemsmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2013, 07:28 PM
  3. Pool party aftermath
    By Poolhouse in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-16-2012, 11:41 AM
  4. Doh! Foam Party In My Pool!
    By troykristoffer in forum Dealing with Algae & Slime
    Last Post: 08-03-2006, 09:50 PM
