Results 1 to 10 of 16
Thread: Will a Krystal Clear Sand Pump and Saltwater System work for my pool?
    Default Re: Will a Krystal Clear Sand Pump and Saltwater System work for my pool?
    After doing some research I believe I have found the adapters I may need
    Please post info on what you found . . . and how it works.
    This is a topic many are interested in, but about which there's not lots of good info.
    Aug 2014
    Here are the parts I have ordered:
    http://www.amazon.com/GAME-4552-Skim.../dp/B004TY7S26
    http://www.amazon.com/GAME-4550-Filt.../dp/B004TN6EEU
    I will update once we receive the items and get them connected.
    Quote Originally Posted by inhope View Post
    Thanks.
    inhope, I hate to put a damper on your plans, but you should know that many above-ground pool manufacturers, especially of metal pools, will void the warranty if you install an SWCG. You may want to read your warranty carefully.
  1. New Pool using Saltwater System
    By ajyoung in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-07-2014, 01:31 PM
  2. Please Help on Intex krystal clear saltwater system
    By eblade21 in forum Intex-type Pool Setup & Operations
    Last Post: 06-01-2014, 07:06 PM
  3. Pump flow rate insufficient for saltwater system
    By Copperhead in forum Intex-type Pool Setup & Operations
    Last Post: 07-18-2013, 06:18 PM
  4. Low flow on intex saltwater/sand system?
    By digitaldoodlebug in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-18-2011, 06:28 PM
