Results 1 to 10 of 14
Thread: Muriatic Acid Useful Life or Expiration Date
    Default Re: Muriatic Acid Useful Life or Expiration Date
    2 gallons of water to 1 gallon of acid will stop the 'fuming' or release of hydrogen chloride gas. This is important, since sodium carbonate (washing soda) + hydrochloric acid (muriatic acid) => carbon dioxide + salt. The carbon dioxide is what will be bubbling up . . . but if the acid is still concentrated will facilitate the release of acid gas fumes.
    Virginia
    Thanks. I’ll give it a try.
    Virginia
    Thanks for the info, Ben.
    I did as you suggested. I had just over two gallons of MA left. It took just under 4 boxes of washing soda (55 oz each I believe) until it stopped reacting with the diluted acid.
    Btw, I visited 4 stores before finding one that had washing soda. ��
    I have a few boxes left. I assume I can use this in the future in the pool to raise pH if needed? I usually have to raise pH at spring opening, and then it stays rock solid all season.
    In our area, Walmart has washing soda and borax in stock more consistently than others.
    FYI "washing soda" = sodium carbonate = 'pH Up' aka 'pH increaser' aka pH+', etc. Contrary to some pool store villains, it's not almost the same, it's exactly the same as what's sold as pH+ and so on.
    And it too, will keep indefinitely, though it will turn into white lumps if it gets damp.
    Virginia
    That’s good to know. I’ll keep the rest inside (climate controlled) to minimize clumping.
    I normally use borax to raise pH, but I used the last I had at opening. It was really clumped up from being stored in the shed.
    I’m glad to be rid of that old MA. I haven’t needed it in years.
    Virginia
    I have some extra boxes of washing soda that I never got around returning, thinking maybe I’d use it at spring opening to raise pH like I normally need to do.
    However, I learned that adding washing soda can raise TA quite a bit, which I normally do not need to do, nor want to do since pH is very stable at my normal TA levels (60-70).
    Is there any other practical use for washing soda? Maybe start using it for laundr until I run out?
    It's an excellent supplement, when washing greasy or oily things -- pot holders, bed sheets used by folks with oil skin, dirty rags, etc -- but you use it along side detergent. Other than that, I don't know of a home use for it.
  1. shelf life of muriatic acid / chorinating liquid
    By hikernut in forum Pool Chemicals & Pool Water Problems
    Last Post: 10-16-2012, 08:56 PM
  2. Does Muriatic Acid Mixed 1:4 Have A Half Life
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-12-2008, 06:58 PM
  3. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  4. How much muriatic acid to add?
    By Blemished_Chemist in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-04-2006, 09:15 AM
