Results 11 to 20 of 21
Thread: I need a pool heater!
    Default Re: I need a pool heater!
    I Have a heat pump and love it(I live in PA). With that said it's pretty useless at 50 degree air temps.
    Quote Originally Posted by MarkC View Post
    Took me 20 times the space to say the same thing!
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    (Even tho my pool's frozen over right now, I still check in. Come on Springtime!)
    I think an important distinction needs to made as to what the source of the heat energy is for the heat pump. Clearly we're talking about using the outside air here. We bought our house with an air-source heat pump (Carrier) and an attractive pellet stove. We thought, 'how quaint, it'll be nice to look at on winter days'. Now we know it's essential to heating the house. As said, when the source of the heat energy drops toward, and below, freezing, efficiency goes out the window.
    That said, heat pumps can be a very efficient way to heat if one uses sub-frostline ground temps as the source.
    There's lots of info on the internets about 'geothermal' energy (50 to 55 degrees) to feed a heatpump and it's something I'm very seriously looking at.
    So, more to the point, I wonder if the same idea doesn't exist for heating a pool as well?
    Chuck
    Ft Lauderdale, Fl
    MOST heat pumps quit below 60 degrees. Because of that there is an option of "heat and cool" in which it will reverse the flow of freon to defrost the ice that forms on the side of the heat pump to stop it from working. Some do this automatically and some require a manual switch. Aqua Cal has this built into the Heat N Cool models and will work down to 23 degrees (albeit at a lower efficiency).
    Sean Assam
    Quote Originally Posted by ChuckD View Post
    Chuck
    I know that there is a constant temp of, I believe, 58 deg F underground, like 3 to 5 feet, depending on location.
    But I've NEVER heard of a heat pump that used THAT as the source of heat! Wow--that's a great idea, if it can be made to work--a sufficiently large heatpump would work no matter HOW cold it got.
    Duanesburg, NY
    CarlD, you of all people! I woulda thought you'd be all over this.
    Start your journey here:
    http://www.geoexchange.org
  7. #17
    I hang my head in shame for my ignorance!
    Ft Lauderdale, Fl
    hmmmm, geothermal heat pumps.
    http://www.symbiontservice.com/geo-thermal/index.html
    Aqua Cal manufactures these.
    Sean Assam
  9. #19
    Duanesburg, NY
    Bingo!
    Got any contacts in upstate NY, ps?
    I'm actually more interested in it for the house than the pool. But it seems to be such an 'exotic' technology, it's tough to find someone knowledgable.
    Chuck
  10. #20
    hoogie is offline ** No working email address ** hoogie 0
    I had a zone off my boiler specifically to heat my pool through a heat exchanger. It worked wonderfully on my small pool(11 k gallons) in MA to bring it from 60 to the low 90's in about 20 hours. Oil use was minimal, about 20 gals to heat it for the weekend. not sure how gas would work but we were hap with the setup we had. During the cooler months like may,june and sept to keep it on say 82 the boiler would run a few hours a day depending on ouside temps of course.
  1. Pool Heater Question
    By kodeblue in forum Pool Equipment & Operations
    Last Post: 04-07-2013, 01:03 PM
  2. Pool Heater
    By tippywanknobi in forum Pool Equipment & Operations
    Last Post: 12-05-2012, 04:23 PM
  3. pool heater ?
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-03-2008, 08:30 AM
  4. best pool heater there has to be one
    By criis in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 09:52 AM
  5. Pool Heater
    By kanane in forum Above-Ground Pool Construction & Repair
    Last Post: 04-19-2006, 12:24 PM
