Thread: pool almost full....as expected bad numbers
    induce is offline ** No working email address ** induce 0
    Default pool almost full....as expected bad numbers
    please forgive mult posts on this topic, but i'm a little edgy on bad (well) water and new pool.
    almost to the skimmer (soon to be skimmer, not yet cut out......maybe today)
    pump and filter prob up tomorrow.
    22k ig vl
    ph 7.1
    TA 450
    CH 380-400
    CL 1.0 (added bleach last night)
    CYA none yet added
    been areating fill water........but numbers are holding. pumps should be running tomorrow. should i go ahead and add acid today? i can stir it up.
    what pH should i shoot for? isn't 7.1 low enough for CO2 to start releasing......?
    starting second areator (sump pump with hose back into pool)
    Jack's purple stuff on deck.......
    Indiana.
    Default Re: pool almost full....as expected bad numbers
    Quote Originally Posted by induce View Post
    No. Your pH is already low and muriatic just sits on the bottom without circulation.
    up and running!!
    pumps been on high 3 days 24/7. polaris fountain on for 3 days also.
    Mult acid adds, bleach, working in CYA, jack's purple stuff in, poly 60 in, water's very clear now.
    today:
    pH 7.6
    cl 0
    cya 20 maybe
    ta 350
    ch 250
    More acid, bleach tonight, more CYA in a sock in the skimmer (thanks for the tip), continue to run fountain.
    much, much better than i thought.
    Until your cya begins to dissolve and you begin to get a reading, it is a good idea to test chlorine morning and evening and add bleach both times. You don't want a new fill to turn green! (You may already be dosing twice a day, but I just couldn't tell from your post.)
    got to 4ppm CL last night.
    this afternoon.......0, oddly enough a bit of CC
    CYA is 40 this afternoon, so i am going to quit adding it.
    Can i shock tonight? 7-10 ppm to raise levels and decrease CC?
  1. How full is full on an easy set pool?
    By Larryh86GT in forum Intex-type Pool Setup & Operations
    Last Post: 06-28-2013, 11:02 PM
  2. Expected life of plaster
    By miker1755 in forum In-Ground Pool Construction and Repair
    Last Post: 08-07-2012, 01:28 PM
  3. TDS much lower than expected
    By wa2asb in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-02-2010, 12:18 AM
  4. Formula to calculate expected Pool Water Temperature???
    By TheG$ in forum Pool Equipment & Operations
    Last Post: 05-11-2007, 07:18 PM
  5. Pool only 1/2 full
    By newtopools in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-12-2006, 03:49 PM
