Results 11 to 19 of 19
Thread: i'm running my pump at night. bad idea ?
    Lehigh Valley, PA
    Default Re: i'm running my pump at night. bad idea ?
    Which improves in proportion to the empties of Yuengling Lager that're tossed over the edge of the deck. O yay!
    Yah, ok. I'm kidding. But these beetles are making my imigination run wild.
    Scottsdale, Arizona
    sorry , can't help you . i'm from az, we don't allow bugs around here
    Quote Originally Posted by AnnaK View Post
    Are you sure it's the beetles and not the lager??
    Quote Originally Posted by maxhiller View Post
    in an attempt to stop the sun from burning out so much chlorine, i thought
    that keeping the water still during the day might help. so i run my pump 6:00PM to 6:00AM instead of during the day.
    (CYA is 50. I keep my chlorine between 3 and 6 as per ben's chart)
    so
    1. does this even make sense to do ?
    2. pool guy has warned against this saying it would promote algae.
    thanks in advance
    max
    In addition to the discussion above in answer to your question, just thought I'd throw a thought in, too... during the hottest part of the summer (remember I'm from Louisiana) I sometimes run my pump at night instead of during the day, too, because it helps cool the water and keep the temp lower...so the pool doesn't become a huge hot tub.
    it may just be a coincidence, but i developed algae.
    i've shocked and am back to daytime hours.
    - max
  6. #16
    North Florida
    FWIW, I try to follow Ben's sage advice over on poolsolutions.com...http://www.poolsolutions.com/gd/avoiding_algae.html...at least 6 hours of pump run time divided into at least 2 time periods.
    My electric provider has no difference in rates during the day, so I run more pump time in the daytime when I'm trying to warm the pool. Just like Janet (aylad) in LA, I schedule more run time overnight when I'm trying to cool the pool a bit. My pool water hit 90 yesterday so I guess I need to make some daytime-to-nighttime adjustments. Currently, I run 2 hours "over lunch" (11a-1p), 4 hours 4p-8p, and another 2 hours 3a-5a, for a total of 8 hours.
    Sandy
  7. #17
    Jul 2006
    West Central Illinois
    Quote Originally Posted by dawndenise View Post
    What kind of timer do you use?
    Bought/installed used Doughboy Summer 2006
    Husband is the muscle; I'm the mixer
    BBB
  8. #18
    North Florida
    An Intermatic PF1102-T (has freeze protection). I believe the newer model of mine is this one: http://www.intermatic.com/Default.as...cid=71&sid=348
    The only thing I would do now is get this type timer that can actually handle 2 different timing sequences: one for the pool pump and one for the Polaris cleaner. As it is now, the Polaris would be on all the time the pump is on unless I manually turn the Polaris switch off.
    Sandy
  9. #19
    keithw is offline Registered+ Thread Analyst keithw 0
    Just out of curiosity, for those who say that they get a lower rate at night so they run their pools at night. How does the electricity know whether you are using the power at night and not during the day to give you that lower rate? I am in VA and I had heard the same about our electric company as well. BUT...The only meter I have at my house is a electric meter on the house with a spinning wheel and numeric readings. They come by and check it every once in awhile (I guess!) but certainly not every morning. It doesn't have any other reporting back to them built into it so I don't see how they would know either way.
  1. Cost of running a pump 24/7
    By Guppy in forum Pool Equipment & Operations
    Last Post: 05-31-2012, 08:37 PM
  2. What to run at night with the pump.
    By xploded in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-13-2011, 07:47 AM
  3. pump running 24/7 or what?
    By airraid1999 in forum Pool Equipment & Operations
    Last Post: 07-09-2011, 06:39 PM
  4. Running pump at night?
    By Cold Drink in forum Pool Equipment & Operations
    Last Post: 08-07-2007, 07:59 PM
  5. running pump
    By nicker in forum Above-Ground Pool Construction & Repair
    Last Post: 07-28-2006, 07:57 PM
