Re: Trying to Swim More and do less work
Morning Reading.
FC - 13 (Held over night - Yippee)
CC - 0
TC - 13
PH - 7.2 (Went up a bit)
Alk - 120 (Went up a bit)
**Water still appears crystal clear with the exception of the ugly bottom of the pool.
I'm at a Crossroad, and could use some advice.
My plan was to let the FC go down on its own today and then I would begin dealing with my metals. However, The weather reports say it is going to Rain.
Q1. Should I continue to keep the FC at Shock level to get past the rain and then start working on my metals? (i'm leaning to yes)
Q2. Under normal pool maintenance, do you bring your FC to shock level after a rainstorm? And if you do, how long do you keep it there?
Q3. Am I the only one on this forum that has this problem?
Revived POP
Intex Blow-up Ring 18x48 round
Cartridge Filter
