Re: Cloudy, then green with a never ending chlorine demand
Hate to see you getting so frustrated. There's almost nothing that normally happens to a pool and its water that the gang here cannot figure out.
You, though, need to keep at it, hammering it with chlorine and daily backwashing, brushing, and vacuuming to waste.
Since you are already up to your ears in it, I suggest you spend the $50-$75 on a FAS-DPD chlorine test kit. There are numerous references on PF for where to find the Taylor K-2006 kit inexpensively or you can go to the Leslies on-line web site and get their clone: The FAS-DPD Service Test Kit. It's the same as the Taylor but it's in a Leslies box.
FAS-DPD will give you a sounder reading on your FC and CC (you'll calculate TC = FC + CC).
It will be far cheaper than 180 yards of fill!
Remember: The most important ingredient you need is P.O.P.P.--Pool Owner Patience and Persistence!
