Re: Converting to salt with a very high CH
Are you sure your numbers are accurate? If I calculate the saturation index using those numbers and a water temperature of 80ºF (and using 7.15 for pH) I get -0.27 which should not be scaling. Was the pH much higher when you opened the pool (or the other numbers)? If so, then that might explain the scaling.
The scale can be redissolved by having the pH kept low (but probably not below 7.0 for too long) along with some brushing and if that doesn't seem to work then there are calcium scale reducing products which are metal sequestrants that are focused on holding calcium and dissolving scale. Others on this forum might have some special tricks for dissolving scale.
