Re: How High To Take Cl2 To Break Down Gunk
I estimated 110 CYA because it took a little above the 100 mark till I could no longer see the dot.
I think her calcium level was about 140ppm. I believe they are on well water. However they have been using the Trichlor tabs not Calcium Hypochlorite.
Thanks for the validation. I thought it was going to take 20-25ppm to burn off the gunk.
Jim
