Re: green pool: like black/green pool
i chlorine tested twice since i got home.
both times, the results were more ridiculous than below.
the last test i:
filled the container up to 10 ml
added two dippers of r870 (presuming dippers are the scoop piece at the end)
water turned and stayed bright pink.
i added r871. to return to colorless, i added 9 drops.
per the instructuions, that is 45ppm. is that possible?
fwiw, the CC was 45 also, as it took 9 drops to bring that test water to colorless)
in all i have added 11 x 1-75 gallons of 6% bleach since sunday.
