Results 1 to 10 of 15
Thread: Variable Speed Pump VS 3050---gpm/rpm?
    Jun 2010
    Texas
    Default Variable Speed Pump VS 3050---gpm/rpm?
    Hi everybody,
    I am relatively new here since I only enjoyed my new pool (SWG, 12000 gal inground gunnite) for about a month or so. When the pool company did the start-up they had me run the 3 hp pump 24/7 on full throttle and after a week reduced it to 4 hours at 2900 rpm and 16 hours at 1500 rpm. Do I really need to run it that much? And can anybody tell me the gpm/rpm? I know this is dependent somehow on where the pump is located, in my case it is on the water surface level at about 20 feet away from the pool. I have heard that I don't need to turnover the pool more than twice a day in summer (we are very heavy users though..).
    Thanks a lot and BTW I did NOT get poolstored during my first poolstore visit, thanks to what I have learnt from here
    Olaf
    Honesdale PA
    Default Re: Variable Speed Pump VS 3050---gpm/rpm?
    Hi Olaf,
    with that pump seems like they have you running in overkill mode. There is a graph on page 32 of the users manual
    http://www.pentairpool.com/pdfs/IntelliPro4x160OM.pdf
    that shows GPM vs RPM vs head. If you look at just the 1500 RPM line and assume not much flow resistance you're probably doing 40 GPM minimum. That's over 38000 gallons on just that speed. Cut it way back and save $$$. The 2X exchange per day is probably a good number. Curious what kind, type, model filter you have. On the high speeds you could easily get into the big pump small filter problem.
    Jun 2010
    Texas
    Thanks, I had seen that graph but what is my TDH? I don't want to go through all the formulas.....
    I have a DE 100 filter and also a Ozonator and they told me for the ozonator to work right, I need the high flow, does that make sense?
    May 2010
    445 9th ave
    Do you have automation, such as an Easytouch system? THat makes flow rates much simpler as there is a spreadsheet that relates RPM and Wattage to determine flow rates.
    16K gal IG, EasyTouch, Intellibrite (2), VS-3050, C&C 200 Filter, IC-40 SWG; Heliocol solar
    Quote Originally Posted by oroepke1 View Post
    TDH is Total Dynamic Head, usually expressed in feet (of water). Dynamic head is the resistance (pressure) associated with water flowing in pipes and through inlets/outlets. Static Head is pressure associated with an elevation difference though usually this is canceled out between the suction and pressure sides of the pump. Static head is more relevant for whether you can prime the pump or to raise water to a solar panel on a high roof.
    Jun 2010
    Texas
    Yes I have an Easytouch System, but haven't played much with it since I spent all of my available time in the water I guess I will dig into the manual sometime soon .....And thanks for the explanation of static and dynamic head!
    I am sure I will be back with questions soon, this is a GREAT forum, thanks!
    Olaf
    mas985's Avatar
    Pleasanton, CA
    There are a couple of ways to get to GPM for the Intelliflo. If you know the wattage that the pump is drawing, the link labeled "Pump Modeling Tools" in my signature, there is a spreadsheet which relates GPM, RPM and watts.
    If you don't have a power reading then I can make guess for you based on some additional information.
    Pipe size and number of runs pool to pad for both suction and return.
    Filter PSI at a given RPM, preferably at a higher RPM.
    Mark
    May 2010
    Asheboro, NC
    Quote Originally Posted by Poconos View Post
    Hi Olaf,
    Wow, understatement of the year. lol
    When I see pool people dump their excess motors on an unsuspecting customer and then blow smoke about ozone, it makes my blood boil.
    This is from their site...
    "Balance water chemistry, shock, and use a sanitizer system. Ozone reduces the amount of chemicals needed and improves water quality, but will not replace your sanitizer."
    With that, why bother at all? Use BBB, save, save, save and have much cleaner water.
    There is no way, no how that a 3 HP motor should be any where near a 12K gallon pool. The "installers" probably piped it out with 1 1/2 inch pipe as well. Sigh!
    I would have them replace the motor with a 1 HP - 1/6 HP, dual speed motor and take their ozone away with that monster 3 HP motor.
    Getting off my soap box now.
    mas985's Avatar
    Pleasanton, CA
    The Intelliflo is both a variable speed pump as well as a variable HP pump. Changing the speed, changes the braking HP of the motor. So in effect, it can emulate any pump on the market at any speed and usually, at better efficiency. While it is true that top speed is the equivalent of a 3 HP pump, nobody said that it ever needs to be run that high and it was probably not necessary during the start up.
    Mark
    Jun 2010
    Texas
    Not sure how I can quote from another email but this was from "Searcher"
    ""There is no way, no how that a 3 HP motor should be any where near a 12K gallon pool. The "installers" probably piped it out with 1 1/2 inch pipe as well. Sigh!"
    I have to defend my PB somewhat. I opted for a larger pump and to run it at lower speeds since I was told that makes sense. I also have a water shear that looks really nice at 80% of full throttle 3hp
    My goal is to run the pumps less, but since I don't know much about the pool yet I decrease runtime gradually and the input I received here is very helpful.
    BTW I used this formula that I found somewhere to calculate head: (2.31 *filter psi + 3)*1.25
    (1.25 is for 25% friction loss, since I have 2 and 2.5 inch pipes, 3 is added since the filter is 3 feet high).
    (2.31*4+3)*1.25 ~15 feet (1500 rpm) from chart: 40 gpm
    2.31*12+3)*1.25 ~40 feet (3000 rpm) from chart 120 gpm
    Does the math make sense? Thanks again for all the help!
    Olaf
  1. Vacuum with variable speed pump
    By ronpbak in forum --cleanup--
    Last Post: 10-04-2012, 05:46 PM
  2. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  3. what speed on a variable pump?
    By bomberchamp in forum Pool Equipment & Operations
    Last Post: 04-11-2012, 11:53 AM
  4. variable speed pump
    By bradc344 in forum Pool Equipment & Operations
    Last Post: 01-16-2012, 09:18 AM
  5. Variable speed pump upgrade
    By kmh in forum Pool Equipment & Operations
    Last Post: 10-17-2011, 08:33 AM
