Results 11 to 13 of 13
Thread: How much CYA in trichlor tablets?
    Default Re: How much CYA in trichlor tablets?
    Quote Originally Posted by HofstraJet View Post
    aylad - I am in SE Florida and also have a pool in the sun all day. I plan on using your method of high CYA. What do you keep your chlorine level at and is there a downside to keeping it lower with a high CYA? Do swimmers find it uncomfortable?
    Thanks!
    I keep my chlorine level between 8-10 at all times. I also shock it after a couple of days of heavy rains, especially if they're hurricane-driven, and at the end of a week of heavy bather load (my house is the place where all the kids on the street hang out all summer).
    I use the best guess chart (link in mine and Watermom's sig) just like we recommend to everybody else. Letting your chlorine get below 5 or 6 with high CYA will result in an algae bloom, and it takes a LOT of bleach once that happens to get it up to shock level, but if you never let it get below 6 to begin with, it's not a problem.
    As for comfort, like Watermom said, higher chlorine with higher CYA feels exactly the same as lower chlorine with lower CYA. Any discomfort is usually caused by letting your pH get out of whack, or letting CC build up without a shock.
    May 2011
    Coral Springs, FL (SE Florida - near Fort Lauderdale)
    Thanks, everyone, for your thoughts. I am adding 50 ppm borates to the pool this weekend and will keep a close eye on things when I start using trichlor tabs next week. My goal is to minimize the amount of active maintenance my pool needs. Pool guy used to come once a week and add liquid chlorine best I can tell, but now that I know what is involved, I see things were certainly out of whack for part of the week as it doesn't really seem possible to maintain a pool with once-a-week maintenance.
    My pool:
    15x30 inground concrete pool w/spa in one corner overflowing into pool, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter
    Jandy Laars LX400 propane heater w/120 gal above-ground tank
    Jandy AquaLink RS OneTouch controller w/PDA remotes and computer control
    JVAs control pool/spa switch and also allow drain opening
    Hayward Navigator
    You are right, once a week maintenance isn't going to work for your pool chemistry but 5 minutes every day or two will!
  1. Unstabilized tablets
    By psandro in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-10-2011, 01:48 PM
  2. HTH Tablets with NO CYA
    By mswlogo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-30-2007, 07:51 AM
  3. Tablets or Granules?
    By bob57 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-31-2006, 09:44 AM
  4. CYA tablets
    By karenkr in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-14-2006, 09:39 AM
  5. Do 3" tablets go bad?
    By rayh78 in forum Pool Equipment & Operations
    Last Post: 06-17-2006, 10:20 PM
