There really is no way to know how much chlorine you'll lose. If your solution got somewhat cloudy, I would say that you have some CYA in there as opposed to none. If you are showing less than 30 and you haven't added any within the last week, maybe add just a little. Maybe enough to add 10ppm. So, even if you are at 30, that would just take you to 40 which would be a good level. A week after adding it, test again and see where you are then. At that point, you can decide if you need to tweak it any.
