Results 1 to 10 of 36
Thread: Using the K-2006
    Jun 2011
    Louisville KY
    Default Re: Using the K-2006
    As long as your water isn't cloudy and your TA isn't high and you don't use cal-hypo, you'll probably be fine and don't need to bother with draining any.
    I have to add water periodically due to evaporation and a small persistent leak from my filter plug. It has not rained here in nearly two weeks, with hot sunny days in the mid to upper 90’s.
    I will monitor the CH level as I recall from reading the K-2006 guide that high calcium levels do something bad.
    Many thanks to you and all the folk here.
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
    Jun 2011
    Louisville KY
    Testing testing testing – the other day my CC test turned yellow.
    Until then it always went clear. The instructions say it may turn pink.
    What’s going on?
    usually partial bleach out from high chlorine (very high). Try the test again with more DPD powder (3-4 scoops). If it still happens dilute your sample 1:1 with distilled water and test with a 10 ml sample then multiply your number of drops by 1 to get the FC and CC.
    Jun 2011
    Louisville KY
    Right on as usual Evan.
    I had upped my chlorine dose to two 1.4 gal jugs to ward off any potential algae bloom since the temps are now in the mid 90’s here and I had a 4th of July party planned.
    So on a hunch yesterday evening I did the 25ml CL test with two dippers and the CC came back clear as store bought glasses.
    Thanks for the tips.
