Thread: Where is the Chlorine going?
    Jul 2011
    Default Where is the Chlorine going?
    My pool is balanced except maybe the Cyanuric acid, which is a little low. BUT: my chlorine levels remain low...in fact, I have 3 Slo Poke tabs in a floater, 2 in the feeder, and one in the skimmer. Still my chlorine levels remain low to nil.
    So today, I put 2 gallons of liquid shock in my 25,000 gallon pool, and I just checked the Chlorine, and it's still NIL!
    Where is my chlorine going?
    Thanks...Neil
    Default Re: Where is the Chlorine going?
    Quote Originally Posted by nrshapiro View Post
    Sounds like you may have answered your own question.
    Add 2 gallons of bleach in the evening (within 2 hours of sunset) -- about 4 ppm of chlorine. Test in the morning within 2 hours of sunrise, then again that evening. If the AM chlorine is 4 ppm or above, and the PM chlorine is low, the problem is either stabilizer OR you used a bromine based product. (Anything from United Chemical; granular chlorine boosters for algae from other companies.) If the chlorine is low in the AM, then you have some sort of chlorine 'demand', from early algae, or pool goop you've added, or ??
    If you want to be sure, post test results: chlorine, pH, stabilizer AND recent history of what you've added to the pool.
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
