Re: HTH 5 Way Test Kit pH results?
I removed the link to the picture in order to speed up the process of getting this post on the forum, but I looked at the pic, and your pH in that pic was 7.2, which is fine to swim in. In fact, your chlorine in that pic was only about 5 ppm, which isn't high at all, if you have no stabilizer.
With high TA, if your pH is staying stable and the TA isn't causing other problems (milky water with high calcium, for example), then I wouldn't worry about it. If it starts causing problems, then you can always adjust it later.
