Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: The use of Lithium Shock
  1. #21
    Jul 2011
    garden city, ks
    Default Re: The use of Lithium Shock
    Gary,
    Would you send me the "Unique Transaction Number" from your PayPal receipt? I have no record of any payment from you. Send it to poolforum AT gmail DOT com.
    Ben
    EDIT by Watermom:
    Goldslinger ---- I deleted the ID number etc. that you had listed here and sent it to Ben along with the rest of what you had written in this post.
  2. #22
    Jul 2011
    garden city, ks
    Here are My pool specs:
    FC = 11.5
    CC = 1.0
    TC = 12.5
    PH = 7.3
    TA = 130
    CYA = 85
    Hope this helps.
    Gary
  3. #23
    Hadn't checked this thread for several days, but there's not much wrong with those numbers. A CC 1.0 might be a concern, but if you've sustained adequate ("Best Guess") chlorine levels, it has probably dropped by now.
    The PayPal thing is, I think, all resolved now.
    Ben
  4. #24
    Quote Originally Posted by goldslinger View Post
    EDIT by Watermom:
    Watermom,
    You might want to check post #18. It still has the transaction ID!
  5. #25
  6. #26
    It's fine to remove them, but I don't think that transaction ID is a big security risk -- the only think I know that you can do with it is make sure that you're looking at the right transaction. If there's a way to access that record by #, or search for it, I didn't find it.
  1. 6% household bleach equivalent to lithium hypochoride granular?
    By magnus in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-24-2013, 10:51 AM
  2. Newbie: To shock or not to shock... That is the question
    By KaseyNewman in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2011, 04:50 PM
  3. Lithium Hypochlorite
    By kanane in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-07-2010, 03:19 PM
  4. To Shock or Not to Shock?
    By cschnurr in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-20-2007, 01:23 PM
  5. When to shock ?
    By Phillbo in forum Dealing with Algae & Slime
    Last Post: 07-18-2007, 11:57 AM
