Thread: thanks for all ur help but stuck with pool measurments...please help
    Default Re: thanks for all ur help but stuck with pool measurments...please help
    I'll see if Waterbear or Waste wants to set in on this -- my knowledge about liner installations is very limited.
    Sorry, Liners are not my strongpoint either. They are not that common here in Florida.
    I guess that leaves me
    Welcome to the Forum!
    Adding up your measurements I come up with a floor length of 36' 10" and a width of 18' 3" . The program they run the custom liners through will 'balk' if the floor measurements don't add up to the overall dimensions.
    Can you tell me how you came up with the dimensions you gave? Did you measure the length and width of the pool, in a couple of places, to be sure it's exactly 18 X 36 and did you check the diagonals to be sure the pool is square and check the panels to see if they are plumb? Did you use a plumb-bob to establish your transition points or just "eyeball" it?
    I've measured for hundreds of replacement liners and will try to help identify why your numbers aren't adding up correctly.
