Results 1 to 10 of 15
Thread: What pump and filter?
    Mar 2012
    Eastern NC
    Default Re: What pump and filter?
    Ok, it looks like I have my mind made up on a sand filter. Thanks for all of your help Mark. I am going to go with this one.
    PNSD0060DO2260 1-1/2* HP Dual Speed
    2.3 sq. ft. effective filtration area
    250# sand filter
    Any suggestions on where to buy? I saw one that was priced good, but almost too good. Is there someone that the forum suggest we use (poolforum.com partner)?
    I feel confident about the filter type. I couldnt find specs on uprated or full or anything like that, so with your expertise is this an energy efficient and quality pump that would be powerful enough for backwashing and vacuuming and strong enough for turnover? If so, I am moving on to the pool.
    mas985's Avatar
    Pleasanton, CA
    Yes, the pump is more than big enough for all your needs. Efficiency will be much better on low speed so try to run it as much as possible on low speed and only use high speed when absolutely necessary.
    Mark
    Quote Originally Posted by jrh1010 View Post
    No partner or recommended source.
    I will note that I've personally used A1PoolParts.com several times, for items I needed for customers locally, and they were cheaper -- selling retail -- than I could buy 'wholesale' from SCP. It was easy to reach someone knowledgeable, and my purchases went well. Of course, that's a small sample, so I'm not 'recommending' them, as much as 'reporting' my own experience.
    Or not. Just checked -- their supply of AG pool equipment (which I don't deal with, locally) is not great. They are in California, and California, like Florida, is a predominantly in-ground market.
