Results 1 to 8 of 8
Thread: New Pool Installed Thursday - Some newbie questions
    Jacob99 is offline Subscriber Thread Analyst Jacob99 0
    Aug 2011
    Massachusetts
    Default New Pool Installed Thursday - Some newbie questions
    My pool was installed Thursday. I have about a foot of water in it now. Liner seems to be okay, no leaks anywhere, and I don't seem to be losing any water so I'll be getting 3 trucks to fill it up on Sunday. I haven't put the sand in my filter yet although all the connections are already in place. It's a 300# Hayward S244T:
    Is the inside spider tube thing suppose to attach (or "clip in" if you will) somewhere or is it just a balancing act while placing the sand inside?
    The filter base has a drain, should I face that drain facing out away from the pool, or does it matter? Is the drain just for the winter?
    This one might be a really dumb question, but do I need to backwash as soon as I start the pump and filter up, or is it ready to filter from the start?
    I guess I'm just nervous about flipping that switch for the very first time....
    Wilbar/Sharkline Tahitian 23,900 gallon 30' Round AG, Hayward 1HP 2-speed pump, Hayward 300# Sand Filter, Taylor K2006c.
    BigDave's Avatar
    Default Re: New Pool Installed Thursday - Some newbie questions
    Quote Originally Posted by Jacob99 View Post
    The long tube with the radial arms (laterals) in my filter (Hayward S270T) just kind of sits on the bottom. Try to center the top of the large tube in the top of the filter and be sure the laterals are attached and extended. My filter came with a carboard "sand shield" that folds into a sort of "A" shape with wings that helps hold the large tube in place and also helps to keep the sand out. I also covered the top of the large tube with a couple layers of cling wrap held on with a rubber band under the "sand shield". Also fill the filter about 1/2 full of water before putting sand in.
    Position it where it will be convenient to get to it when you drain the filter and where what drains out will go where you want. Be sure the strainer is in it and the cap on before filling the filter with water and sand.
    ... do I need to backwash as soon as I start the pump and filter up ...
    Yep, start in backwash to get the dust out of the sand and not in your pool. Remember, you can't do this 'till the pool is full to half way up the strainer.
    Please don't misunderstand, I'm totally happy to answer your questions as are many here but in case you didn't get one, here's the manual http://www.hayward-pool.com/pdf/manuals/Manual145.pdf.
    Goog Luck! Keep us posted!
    Aug 2011
    Massachusetts
    Thanks. I appreciate it. Should I add some DE to it from the start or wait until I know what my normal pressure is?
    Aug 2011
    Massachusetts
    So just filled the pool (it's about 1/4 way up the skimmer now)...I'm getting a steady drip out of my sand filter. I checked to make sure the strainer was in and the drain plug is tight. I don't know if I should tighten it some more....don't want to over tighten it. I haven't turned anything on yet as I still need 2-3 more inches of water. Should I overtighten it, or are drips normal the first time you get water in there?
    BigDave's Avatar
    The drip is from the drain cap? Is yours the black star shaped cap with a red ruber seal inside? I had a drip from that too. I had to get it very tight to stop the drip - hand tight but I had to work at it.
    Apr 2012
    Texas
    Where's it dripping from? Did you tighten the drain cap before you put the sand in or after...you might be in for a little more work than you wanted
    18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
    ; community; PF:16
    Aug 2011
    Massachusetts
    After. It was already on while I was putting the sand in, but I tightened after. I gave it a couple more hand turns and it seems to have stopped.
  1. newbie with pool construction questions
    By gch.3 in forum Above-Ground Pool Construction & Repair
    Last Post: 02-19-2012, 01:49 AM
  2. A pool newbie with a few questions!
    By mama_to_one08 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-07-2010, 03:56 PM
  3. Mars HP Freshly installed - First Impressions/Questions
    By caustik in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-30-2007, 07:20 PM
  4. Pool Newbie w/ questions galore!
    By Pollysunshine in forum Above-Ground Pool Construction & Repair
    Last Post: 08-06-2006, 05:44 PM
  5. Just installed SWG, questions on salt level
    By noworries in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-16-2006, 03:12 AM
