OK.
1. CYA will drop over time -- like a couple of seasons. It will be VERY important to not let the pool get slimy over the winter; if you do, you'll probably have to drain and refill.
2. High chlorine can interfere with pH test results; high CYA does not. You may yet have to get a pH meter, but let me check.
3. Some of the questions you've asked can be answered better, if we know your equipment: pump / filter make & model.
4. I got the pool photo you sent -- does the pool look like that right now? What color / location / texture is the algae you have. Regardless, if you have algae, go ahead and add a quart of the poly quat (36K gallons, right?).
5. When are you going to be "venting" pool water? Why? How much?
6. Do you have any copper staining, from the algaecides? When did you add those? Exactly how much did you add, and what was the exact product name? How important is it to you to NOT have blue-green stains?
If you've got some algae now, you'll probably need some sodium bromide, to create a free halogen residual. But, we can wait a bit longer on that.
