Results 11 to 20 of 30
Thread: Kem Tek 338 vs Jack's Magic Purple Stuff in salt pool?
    Virginia
    Default Re: Kem Tek 338 vs Jack's Magic Purple Stuff in salt pool?
    I thought that the pink and blue stuff were the same strength. I seem to remember seeing that somewhere, either on the bottles themselves of in some of the Jack's Magic Literature. I could be wrong.
    I took a look at the bottle and there's nothing listing ingredients or concentrations. It's interesting that the dosing instructions for the Pink Stuff and Purple Stuff are exactly the same to reach the same level (10-12ppm).
    I did see this on the Purple Stuff bottle in addition to its claims to "remove" metals; "...helps keep silica in solution and helps prevent scaling of cells in salt water chlorine generator systems..." What exactly does this mean? Anything?
    Found this on poolgeek.com (where I buy Jack's Magic) about the Purple Stuff; "A concentrated blend of stain preventing and sequesting agents."
    And this about the Pink Stuff; "A professional strength blend of sequestering agents."
    This seems to point to some difference in strength.
    Then there's the Magenta Stuff for salt pools. Instead of HEDP is uses "Acrylic Acid Copolymer". Any idea what this is and it's effectiveness?
    Quote Originally Posted by JimK View Post
    PAA - Polyacrylic acid, used to make disposable diapers, among other things. Google for more info.
    Virginia
    I Googled it, found alot of stuff speaking over my head.
    Is it effective?
    don't really know.
    It's a common ingredient in polymeric clarifiers. Because it has many negatively charged sites on the polymer chains it can 'grab' positively charged molecules and clump them so they can be filtered out more efficiently and can also temporarily bond metal ions such as calcium and magnesium so it has a 'water softening' effect. (This is why it is also added to Clorox bleach and some laundry detergent formulas since the larger "clumps do not redeposit as readily on clothes.)
    Does it work? As well as any other polymeric clarifier. Overdosing can cause particles to form a colloidial suspension that is almost impossible to filter out instead of forming larger, filterable "clumps"
  6. #16
    Virginia
    ...... Overdosing can cause particles to form a colloidial suspension that is almost impossible to filter out instead of forming larger, filterable "clumps"
    Guess I won't be using that.
    According the Jack's Magic, one of the benefits of this is that it doesn't add phosphates to the pool like HEDP does. Do phosphates matter in a pool with with borates (I try to maintain 50ppm)?
  7. #17
    If you remove nearly all phosphates, algae has a hard time growing.
    If you maintain 50+ ppm borates, algae has a harder time growing, though I doubt the effect is as great as with PO4<100 ppb
    If you maintain constant chlorination at FC=10% of CYA, as far as we know, algae will not get started, though once established, some algae colonies will persist.
  8. #18
    Virginia
    Great info.
    While I haven't maintained chlorine at 10% of CYA (I maintain FC 4-5 at 60-80 CYA), I do try to keep borates at 50ppm and add a phosphate remover when closing the pool for the season to keep phosphates down. Since starting this practice many seasons ago I've not had any algae outbreaks. Someone mentioned the phosphate treatment at closing probably wasn't necessary, but I think I'll stick with it since this routine seems to work well for my pool.
    Perhaps the combination of low phosphates and the addition of borates is a double wammy for algae. Although I've not tried it yet, I'm thinking I might be able to discontinue the weekly polyquat (60%) doses. Perhaps I'll try that next season since I already have my supply of polyquat for this season.
    Also, if the bucket test for metals comes back negative (I'll know tonight), perhaps I can also stop, or greatly reduce, the addition of the sequestrant (Jack's Magic Purple Stuff).
    Thanks again for taking the time to help us.
  9. #19
    Virginia
    Ben, when I checked the bucket this evening the water was still cloudy from the addition of washing soda. When first I started the test and added the chlorine, the water got cloudy, but cleared the next day (I didn't see any staining or sediments). When I then added the washing soda, it got cloudy again, but this time it has not cleared after more than 24hrs so I cannot see if there are any stains or sediments.
    Any suggestions on how to proceed?
  10. #20
  1. Jacks Purple Stuff Alternative
    By Simmons99 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 09-01-2006, 12:58 AM
  2. Jacks Purple Stuff Alternative
    By Simmons99 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-30-2006, 03:53 PM
  3. Jack's Magic Purple Stuff for SWG?
    By johndoe74 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-16-2006, 04:24 AM
  4. Jack's Purple Stuff Questions
    By mkamp1515 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 12:13 AM
  5. Jack's Magic Blue Stuff
    By EricH in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-15-2006, 04:27 PM
