Results 1 to 10 of 14
Thread: Is this a correct pump to use for a above ground swimming pool
    Jun 2012
    Florida
    Default Re: Is this a correct pump to use for a above ground swimming pool
    The guy we get it from, set he runs it every day for 2 hours.
    We also wanna buy this Saltwater pool filter, because its much better for kids eyes
    http://www.lowes.com/pd_317880-15697...ter&facetInfo=
    what would be a good pump for this 45 gallon pool? with this saltwater poolfilter?
    Quote Originally Posted by qbinflorida View Post
    what would be a good pumpr this 45 gallon pool? with this saltwater poolfilter?
    Probably, the matching Intex pump would be your best choice. However, it appears you can get it more cheaply, AND more simply by buying the combo package, which includes BOTH the pump, and the saltwater system:
    Intex 54611EG Krystal Clear Saltwater System and Filter Pump @ Amazon
    Use that link to check it out, but before you buy, make sure you understand the price and who's shipping. Today ( June 6, 2012), it ships free directly from Amazon for $230, and is a good deal. But, if Amazon goes out of stock, the link will bounce you to a 3rd-party Amazon seller, with different pricing and shipping. It might even be a better deal, but just make sure you pay attention.
    Just a reminder that both of the above systems also include a copper ionizer and add copper to the water, which is not a good idea if any blonds or anyone with tinted, bleached, hilighted, permed, relaxed, or damaged hair (including sun bleached) go in the pool because of the possibility of the hair turning green.
    I saw a lot of copper green hair in my previous life as a hair colorist in Miami, FL!
    Thanks. Should have mentioned that AND the fact that you can unplug the wire to the copper electrode.
    Jun 2012
    Florida
    Darn, my little girl has dark blond hair.
    But for the rest nobody in this family has tinted, bleached, hilighted, permed, relaxed, or damaged hair (including sun bleached)
    Is it really that bad, that you would say buy something different? if yes, what???
    Sorry for my bad english by the way i'm from Amsterdam and just moved to florida
    Dark blond hair is not as much of a problem. But the almost white blonde hair that's pretty common among Dutch children will just about turn green if you drop a copper penny in a pool.
    Watch her hair; if it begins to turn green, you can remove it with lemon juice (citric acid). Then, disconnect the wire to the copper electrodes, and that should solve the problem.
    Jun 2012
    Florida
    Thanks for al those tips. there are very helpfull.
    Can i not Disconnect the wire to the copper electrodes from the beginning?
    And then i will not have this problem thats my daughter maybe gets green hair.
    Yes, absolutely.
    Jun 2012
    Florida
    Sound indeed like a good deal, then we have a new pump, and a saltwater systeem
    Thanks for the tip ;-)
    Think we gonna go for this package then for $230 :P
    Can use the other pump then, to put a sprinkler systeem in my yard, instead of trowing it away.
    P.s this systeem is good for a 4500 Gallon above ground pool?
    Because i just see that in my post is standing 45 gallon, need to be 4500 gallon
  1. correct pump for my filter
    By mike in arkansas in forum Pool Equipment & Operations
    Last Post: 07-20-2012, 12:12 AM
  2. Correct Pump Size for Filter
    By RobDHW in forum Pool Equipment & Operations
    Last Post: 05-18-2011, 11:27 AM
  3. HELP! How to pick the correct pump/filter ??
    By darenjones in forum Above-Ground Pool Construction & Repair
    Last Post: 06-25-2007, 12:38 PM
  4. Correct Pump/Filter?
    By cpmart in forum Pool Equipment & Operations
    Last Post: 08-23-2006, 10:34 PM
