Results 1 to 10 of 62
Thread: slimy, gelatinous strings of goo ruin a good dip.........
    Jun 2012
    New York
    Default Re: slimy, gelatinous strings of goo ruin a good dip.........
    I am convinced the staining is from the gigantic amount of borax I put in the pool. I did not realize it didn't instantly dissolve when I poured it in and i let it just sit there. You can see where it sat and where it spread out to. I should probably have used the brush to move it around. (Incidentally, what I thought was algae was the staining).
    Any ideas?
    Quote Originally Posted by heyred52 View Post
    I am convinced the staining is from the gigantic amount of borax I put in the pool. I should probably have used the brush to move it around.
    Borax doesn't dissolve instantly, which is why we try to always tell people to add it via the skimmer. However, borax itself won't stain anything. What probably has happened is that the iron in your pool water was precipitated out when you added the borax that way. I've already covered the topic of iron removal pretty fully.
  1. Opened to a slimy pool:(
    By freddyttt in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-23-2009, 05:14 PM
  2. Brown Slimy Foam
    By cheesemaster in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-05-2009, 12:59 AM
  3. Slimy black goo
    By Sumo1 in forum Dealing with Algae & Slime
    Last Post: 05-02-2007, 12:34 PM
  4. Can Spring Sludge Ruin My Filter?
    By CoffeeBean in forum Dealing with Algae & Slime
    Last Post: 06-09-2006, 08:43 AM
