Results 1 to 10 of 12
Thread: New pool owner getting frustrated with costs
    Jul 2012
    North Carolina
    Default Re: New pool owner getting frustrated with costs
    I appreciate the quick feedback. I did order a test kit and am looking forward to "freeing" myself from the pool store. My wife thinks I am a bit crazy and is skeptical of everything I am doing so far.
    I will take the advice and live with it for now. I am having another issue though and am hesitant to act until I get my test kit.
    My new issue and this one is far worse than the dark stain. My salt level is showing as 0. I have tried resetting the unit and getting a new reading but nothing. It seems as if I was stuck in time for a while. I bought my house 3 weeks ago and had to add 7 bags of beginnings. I have kept up with the renewal and had a reading of 3100. Then it just stopped and went to 500 and has gone down to 0 in less than 24 hours. Once it was so low I added 240lbs of mortons pool salt and the number went down even further. I checked my chlorine with my tabs and it was 0. So I added bleach to shock the pool.
    BTW. I took a sample to the pool store and they just had me get some balance pack 100 and maintain 100. Was told I was low on CLA and needed to stabilize.
    Is this a sign that my cell is going bad?
    I think it is best to just stop and wait for my test kit.
    I know this is kind of a random post but I am kind of freaking out and now my wife is giving me those "I told you" eyes.
    Quote Originally Posted by jaff50 View Post
    Yep. We hear that a lot. Not as much as I did 15 years ago, but still fairly often.
    You can
    + show her the ingredients on the "Balance Pak 100" -- "sodium hydrogen carbonate" I believe they have it.
    + Then Google and find the definition ( http://www.thefreedictionary.com/sod...ogen+carbonate )
    + Finally, write down the price per lb of the INDUSTRIAL grade of sodium hydrogen carbonate, in Balance Pak 100, and
    + Compare it with the price for the FOOD grade of the same chemical, here: www.walmart.com/ip/10291025
    See if she still thinks they are looking out for y'all!
    The Maintain 100 is just stabilizer. At $3/lb for Kem-Tek dichor, you are paying $6/lb for stabilizer (it's 50% stabilizer by weight). But, of course, it's also chlorine. The "Maintain 100" is *just* stabilizer, and often sold for around $6/lb.
    Regarding salt levels, it's quite possible that your SWCG has some sort of sensing problem. If you post your EXACT make and model, there's a fair chance someone can help you with the diagnostic.
    However it's a good idea to go ahead and get the AquaCheck salt test strips -- these are a very innovative test method, that (unlike most AquaChek products) seems to be quite accurate.
    Jul 2012
    North Carolina
    My wife read through the posts and laughed but I think she gets it now.
    So, I took your advice and picked up the aquachem salt test strips. I am getting a reading of 4 which translates over to 1160. This is very low especially since I added 240 pounds of salt this weekend.
    My SWG is a compupool generic aquarite replacement T cell 15.
    Hey! I'm pretty sure I have those kind of eyes, too! (Should I ask my family?? Nah. I already know the answer!
    Jul 2012
    North Carolina
    Smile Re: New pool owner getting frustrated with costs
    I believe I figured it out!!! My wife called the 800 number on the box and ran through the tests. Well our volts are very low 14-19 range. I googled it when I came home from work and it led me here to the forums. Well, it seems I have a bad limiter. The quarter sized black piece. I took the panel apart and smelled it and looked at the back (even had my wife smell it to confirm). So I immediately ordered 2 from digikey.com I ordered them today and they have already shipped.I am hoping to have it fixed this weekend. I will keep you posted to my results.
    I appreciate all the help.
    Please do.
    But also remember that SWCG work best when your water is in good shape; when things go wrong, you need to shut it off and take over!
    Jul 2012
    North Carolina
    Finally got it, It was the resistor. I bought 2 just in case and it was really simple to de-solder the old one and replace it with a new one. All is well now. I have followed everyones advice and have my own test kit now. It is a Taylor 2006. Looking back I wish I had read a bit further into the test kits and purchased one that I could test bromine as well. I have a salt pool and a bromine spa. Either way we are enjoying are swimming pool and are still working on getting everything else taken care of.
    It can test bromine.
    No available test kit usable at pool side can distinguish bromine from chlorine. All test methods -- OTO, DPD, syringaldazine (strips) are actually halogen tests, and so react indiscriminately to chlorine, bromine, iodine . . .or if you are into expensive radioactive methods, astatine!
    To test bromine with your K2006, just fill to the 10ml level, count your drops, and multiple each drop by 1.13 instead of 0.5. That will be your bromine level!
